Gaines09
Aug 01, 2018Tutor
internet seems to drop out constantly and causes high latency while gaming
So I've been told by spectrum a few times that the problem is within my modem and router. I bought a new modem and router and I still seem to be having the same issues. It seems the internet connecti...
Hungovermonty
Aug 02, 2018Aspirant
I'm having the exact same issues don't know what to do
- Gaines09Aug 02, 2018TutorLet me know if you find out what it is!
- HungovermontyAug 02, 2018AspirantI've tried everything but still the same very disappointed with my purchase
Had an x4s router before this one and had zero problems- Netduma-FraserAug 02, 2018NetDuma PartnerIf it happened pre xr500 then it can't be the routers fault. Suggest you do the tests i said above to monitor your line
- Netduma-FraserAug 02, 2018NetDuma PartnerHungover - issues pre xr500?
- Gaines09Aug 02, 2018TutorIt has been happening for the past few months. Spectrum keeps blaming it on my modem so I bought a new one and the issue is still present.
