Gaines09
Aug 01, 2018Tutor
internet seems to drop out constantly and causes high latency while gaming
So I've been told by spectrum a few times that the problem is within my modem and router. I bought a new modem and router and I still seem to be having the same issues. It seems the internet connecti...
Hungovermonty
Aug 02, 2018Aspirant
I'm having the exact same issues don't know what to do
Gaines09
Aug 02, 2018Tutor
Let me know if you find out what it is!
- HungovermontyAug 02, 2018AspirantI've tried everything but still the same very disappointed with my purchase
Had an x4s router before this one and had zero problems- Netduma-FraserAug 02, 2018NetDuma PartnerIf it happened pre xr500 then it can't be the routers fault. Suggest you do the tests i said above to monitor your line
- Gaines09Aug 03, 2018Tutor
Would you like me to post my findings here? I sure wouldn't know what to look for.
