DuButler72
Aug 12, 2019Aspirant
Internet Settings
I am a newbie when it comes to setting up my tech devices. Just recently purchased an XR500 and feel pretty good about the QoS and Geo Filter settings. Where I am getting bogged down and need the mos...
- Aug 15, 2019Yes that sounds fine. Doesn't look like it's possible on iPhone but take a look at this guide and it should give you next steps: https://www.howtogeek.com/197268/how-to-find-the-best-wi-fi-channel-for-your-router-on-any-operating-system/
Netduma-Fraser
Aug 13, 2019NetDuma Partner
Unless you know what you need to do then I would mostly leave WAN and LAN alone. For the most part you should just be able to leave wireless setup as it is as you will have decided to use smart connect or not during the setup wizard. If you want to connect to the 2.4GHz or 5GHz channels individually then you could change this. I would leave 2.4GHz on auto channel and for 5GHz you could leave it as is or you could use a WiFi analyser to find the least congested channel and change to that.
- DuButler72Aug 14, 2019Aspirant
Thank you for the reply.
I may have accidentally changed the 5GHZ channel and mode. Currently on channel 153 and mode is 1733 Mbps. Does this sound right?
Also, can you recommed a wi fi analyzer for an Iphone that will give me the information i'm looking for (channel traffic)?
Thanks in advance for you support!
- Netduma-FraserAug 15, 2019NetDuma PartnerYes that sounds fine. Doesn't look like it's possible on iPhone but take a look at this guide and it should give you next steps: https://www.howtogeek.com/197268/how-to-find-the-best-wi-fi-channel-for-your-router-on-any-operating-system/
