thowell
Jan 13, 2020Follower
Internet Slows Down When Nighthawk Is Plugged In
HELP!!!! When my Nighthawk is up and running, the internet speed is EXTREMELY low. If I run speed test within the router, the numbers are as they should be, but they do not reflect the actual speed. I will then run a speed test through my browser and the numbers will be so low that it does not come within 350mbps of what I pay for.
Additional info: When I do not use the Nighthawk, my speeds are where they should be.
1 Reply
- Netduma_AlexNetDuma Partner
In order to help us narrow down the problem, could you go to QoS, open the anti-bufferbloat side menu, and tick Disable QoS.
Now do another speedtest.
