BretD
Jan 08, 2018Administrator
Introducing: Nighthawk Pro Gaming WiFI Router XR500
This new groundbreaking NETGEAR Nighthawk Pro Gaming WiFi Router (XR500) leverages advanced cutting-edge software to optimize network connections by stabilizing ping, reducing lag spikes, and...
bacevedo
Jan 22, 2018NETGEAR Employee Retired
The great thing about this router is you can plug your PC, PS4 or Xbox into the 4 ports in the back. I'm playing with 16ms ping on my Xbox wired. If you are a mobile gamer playing Clash Royale or any persistant world or a mobile game that depends on Peer to Peer, your connection will be solid as well.
rusky1
Jan 22, 2018Tutor
Thanks for your replies I am grateful and they are very helpful, to Bacevedo sounds like you have one if you wouldnt mind looking at
the details on the power adapter connected to your xr500 and let us know the power voltage it has It would be appreciated
R
- BretDJan 23, 2018Administrator
R
My power adaptor says 12vdc 3.5A Tip positive.
- AbhayBJan 23, 2018NETGEAR Employee Retired
It is a full-range power adapter so you can use it in Australia with a simple adapter.
Abhay
- rusky1Jan 25, 2018Tutor
Thankyou so much for that bit if information AbhayB.It was exactly the detail I needed for confidence of buying
the nighthawk xr500 from Amazon US to Australia.I still have to ask the wife but cheers again and thanks
everyone for the help
