BretD
Jan 08, 2018Administrator
Introducing: Nighthawk Pro Gaming WiFI Router XR500
This new groundbreaking NETGEAR Nighthawk Pro Gaming WiFi Router (XR500) leverages advanced cutting-edge software to optimize network connections by stabilizing ping, reducing lag spikes, and...
BretD
Jan 23, 2018Administrator
rusky1 wrote:
Thanks for your replies I am grateful and they are very helpful, to Bacevedo sounds like you have one if you wouldnt mind looking at
the details on the power adapter connected to your xr500 and let us know the power voltage it has It would be appreciated
R
My power adaptor says 12vdc 3.5A Tip positive.
AbhayB
Jan 24, 2018NETGEAR Employee Retired
It is a full-range power adapter so you can use it in Australia with a simple adapter.
Abhay
- rusky1Jan 25, 2018Tutor
Thankyou so much for that bit if information AbhayB.It was exactly the detail I needed for confidence of buying
the nighthawk xr500 from Amazon US to Australia.I still have to ask the wife but cheers again and thanks
everyone for the help
