iTzPedroHDi
Jun 25, 2021Aspirant
invalid rpc request
I bought a Nighthawk XR1000 and i keep getting this error invalid rpc request message i try reseting to factory settings updateing fireware but it say im in the newst fireware
iTzPedroHDi
Jul 02, 2021Aspirant
reset to factury setting my holding the reset button with a paper clip for 10 sec
i get the massage ever 10 to 15 sec also the http://192.168.1.1/ takes too long to load up
Netduma-Fraser
Jul 03, 2021NetDuma Partner
You will need to hold the reset button for 30 seconds, then release, wait 2 minutes for it to reboot properly then access it and see if it's working properly.
- iTzPedroHDiJul 03, 2021Aspirant
i did this i still get the massage and it takes a long time to load up the pages
- Netduma-FraserJul 03, 2021NetDuma PartnerHave you got Armor enabled? Does it disappear if you use the Microsoft Edge browser
No, and i try chrome and edge browsers and still get the massage
