ipponz
Jul 13, 2019Aspirant
Invisible Players Destiny 2
Hello, I have a Netgear XR500 Gaming Router and in Destiny PvP the enemy players are often invisible. I can shoot them and i see them shooting at me, but still they are invisible. The only setti...
- Jul 16, 2019Glad to hear you haven't experienced it recently, have the other players found what the cause was? It sounds more like a server issue to me and that would make sense if without changing anything it's now working correctly. If it was an issue with the Geo-Filter then you probably wouldn't be put in the game in the first place.
Netduma_Alex
Jul 15, 2019NetDuma Partner
When you say invisible, you mean you can't see them? Their character models aren't there?
ipponz
Jul 16, 2019Aspirant
Hi,
Yes, their characters are invisible, as are my equipped weapons.
But i saw that there are also other players experiencing the same problem on Bungie forum.
Haven't experienced it for a couple of days now.
Thanks for your reply.
- Netduma-FraserJul 16, 2019NetDuma PartnerGlad to hear you haven't experienced it recently, have the other players found what the cause was? It sounds more like a server issue to me and that would make sense if without changing anything it's now working correctly. If it was an issue with the Geo-Filter then you probably wouldn't be put in the game in the first place.
