ipponz
Jul 13, 2019Aspirant
Invisible Players Destiny 2
Hello, I have a Netgear XR500 Gaming Router and in Destiny PvP the enemy players are often invisible. I can shoot them and i see them shooting at me, but still they are invisible. The only setti...
- Jul 16, 2019Glad to hear you haven't experienced it recently, have the other players found what the cause was? It sounds more like a server issue to me and that would make sense if without changing anything it's now working correctly. If it was an issue with the Geo-Filter then you probably wouldn't be put in the game in the first place.
ipponz
Jul 16, 2019Aspirant
Hi,
Yes, their characters are invisible, as are my equipped weapons.
But i saw that there are also other players experiencing the same problem on Bungie forum.
Haven't experienced it for a couple of days now.
Thanks for your reply.
Netduma-Fraser
Jul 16, 2019NetDuma Partner
