mathews
Jun 03, 2022Initiate
ipad mini 1st generation Fails XR1000 WiFi at Userid, Password. Only Password for other connections?
ipad mini 1st generation will not connect, fails after requesting Userid Password; XR1000 Connects perfectly to Macbook Pro and iphone12, also No Userid Requested. The ipad mini 1st generatio...
- Jun 06, 2022
SOLVED. the problem was the iPad was attempting to connect in Enterprise mode AND WPA2 like the rest of my stuff in WPA3. So the Solution Is twofold 1) XR1000 thru DumaOS make No changes to 5G band, however change the 2.4G band to broadcasting WPA2 and 2) iPad > Wi-Fi On > Other > Choose WPA and NOT Enterprise WPA. And the iPad 1st Gen is on the internet! Now if only I was an SQL programmer..
Netduma-Fraser
Jun 04, 2022NetDuma Partner
The only possible thing it could be is the SSID I would have thought as there is no username that goes along with connecting to WiFi. Are you using Smart Connect on the XR1000? If so that is possibly why, older devices don't really know how to handle it so disable that then connect manually to 2.4 or 5GHz and see if it works
