mathews
Jun 03, 2022Initiate
ipad mini 1st generation Fails XR1000 WiFi at Userid, Password. Only Password for other connections?
ipad mini 1st generation will not connect, fails after requesting Userid Password; XR1000 Connects perfectly to Macbook Pro and iphone12, also No Userid Requested. The ipad mini 1st generatio...
- Jun 06, 2022
SOLVED. the problem was the iPad was attempting to connect in Enterprise mode AND WPA2 like the rest of my stuff in WPA3. So the Solution Is twofold 1) XR1000 thru DumaOS make No changes to 5G band, however change the 2.4G band to broadcasting WPA2 and 2) iPad > Wi-Fi On > Other > Choose WPA and NOT Enterprise WPA. And the iPad 1st Gen is on the internet! Now if only I was an SQL programmer..
Jun 06, 2022Guru - Experienced User
What security mode are you using on the router? Temporarily turn OFF Wifi security and see if the pad connects.
Try WPA2 and TPIK. Then try AES.
The ipad mini 1st generation requests Userid, Password to connect to WiFi network of the XR1000, which is strange because all other connections to XR1000 just request Password.
Have tried all kinds of "Userid's"; SSID?? Netgear64, Netgear64-5G, "admin", null, email Userid(s) with their respective Passwords resulting in No Joy.
Ipad mini 1st generation is updated to latest 9..3.6 (yes apple is no longer updating)
XR1000 is updated to latest firmware.
Have reset network setting on the ipad mini
Have rebooted XR100 (a few times).
Any Ideas of what Userid the ipad mini is requesting?
Any other suggestions welcome!
- mathewsJun 06, 2022Initiate
