ROBODOG
Jul 14, 2018Aspirant
IPv6 Manual DNS boxes
So I am manually trying to put the ipv6 cloudflare numbers into my router. The cloudflare dns numers are a series of 4, 4 digit numbers (2606:4700:4700::1111). But in my settings there are 8 boxes fo...
Netduma-Fraser
Jul 15, 2018NetDuma Partner
Check to see if your DNS has applied: https://ipleak.net/
If not maybe worth calling Netgear support
ROBODOG
Jul 16, 2018Aspirant
Thanks! Using the link looks like its nor working. I still havent figured it out or heard back from Netgear.
- Netduma-FraserJul 16, 2018NetDuma PartnerDarren can you help out with an update on Robos case?
- ROBODOGJul 16, 2018Aspirant
I just saw on another post that I am supposed use four zero's as replacement for the double colon
2606:4700:4700:0:0:0:0:1111
anyone know if this is thright way to do this or not?
- Endorphine71Jul 17, 2018Apprentice
The double colon means to put the last number at the end. Should look like this:
