ROBODOG
Jul 14, 2018Aspirant
IPv6 Manual DNS boxes
So I am manually trying to put the ipv6 cloudflare numbers into my router. The cloudflare dns numers are a series of 4, 4 digit numbers (2606:4700:4700::1111). But in my settings there are 8 boxes fo...
Netduma-Fraser
Jul 16, 2018NetDuma Partner
Darren can you help out with an update on Robos case?
ROBODOG
Jul 16, 2018Aspirant
I just saw on another post that I am supposed use four zero's as replacement for the double colon
2606:4700:4700:0:0:0:0:1111
anyone know if this is thright way to do this or not?
- Endorphine71Jul 17, 2018Apprentice
The double colon means to put the last number at the end. Should look like this:
