latinkreationz
Feb 25, 2018Star
IPv6 Manual DNS
I'm using OpenDNS for both IPv4 and IPv6. When I look at my settings in the Netgear Up app, it shows the DNS resolvers pulling from my ISP for IPv6 rather than the manual ones I entered. IPv4 resol...
- Mar 04, 2018
I just wanted to give an update. So it seems if Auto-Detect is used when setting up IPv6, no matter what manual DNS servers are entered, the ones auto retrieved from the ISP are used. Once I switched the setting to DHCP, then the manual DNS servers I entered are used.
Netduma-Fraser
Feb 25, 2018NetDuma Partner
I’ve not used up App myself. You’re probably best to contact Netgear directly through their official support: https://www.netgear.com/support/contact.aspx
latinkreationz
Mar 04, 2018Star
- Netduma-FraserMar 04, 2018NetDuma PartnerThanks for the update! I will make a note of this and bring it up to the Netgear team to get fixed. Glad that you managed to resolve the issue.
