jeremyg237
Feb 09, 2021Luminary
IPV6 not working on XR1000
Ok so here we go. 1. Model does not show in model for topic. 2. I have owned the following: orginal NETDUMA, XR500 and now the XR1000. 3. My XR500 IPV6 worked fine. 4. IPV6 will not work rega...
Netduma-Fraser
Feb 09, 2021NetDuma Partner
Which firmware are you on currently? I assume you're using modem > XR1000?
- jeremyg237Feb 09, 2021Luminary
I actually disconnected and am using the XR500. When I first turned it on it made me do an update. So imagine the newest one out there. If you want I can hook it up to see.
Also it is not a modem. It is the Nighthawk pro gaming XR1000 wifi 6 gaming router. Does not give me a warm and fuzzy that you thought I was talking about a modem. When in the discription I was saying how I could not get the IPV6 to work on the router after I changed it out with my old one.
Im also using a CM1000 Netgear modem. Not sure if that what you meant earlier.
