jeremyg237
Feb 09, 2021Luminary
IPV6 not working on XR1000
Ok so here we go. 1. Model does not show in model for topic. 2. I have owned the following: orginal NETDUMA, XR500 and now the XR1000. 3. My XR500 IPV6 worked fine. 4. IPV6 will not work rega...
Netduma-Fraser
Feb 09, 2021NetDuma Partner
Which firmware are you on currently? I assume you're using modem > XR1000?
jeremyg237
I actually disconnected and am using the XR500. When I first turned it on it made me do an update. So imagine the newest one out there. If you want I can hook it up to see.
- jeremyg237Feb 09, 2021Luminary
Also it is not a modem. It is the Nighthawk pro gaming XR1000 wifi 6 gaming router. Does not give me a warm and fuzzy that you thought I was talking about a modem. When in the discription I was saying how I could not get the IPV6 to work on the router after I changed it out with my old one.
Im also using a CM1000 Netgear modem. Not sure if that what you meant earlier.
Decided to try some troubleshooting.
1. Firmware was lastest version 38. I also tried 36. Both did not work.
2. Rebooted modem, update PC to include windows. On 38 and 36 Did not work.
3. Tried setup wizard on 38 and 36. It also detected DHCP, but still did not work.
Tried Auto config, dhcp and auto detect in firmware 38 and 36. Did not work.
When I look on the IPVS page it is showing DHCP addresses under WAN and LAN. But still does not work.
