jeremyg237
Feb 09, 2021Luminary
IPV6 not working on XR1000
Ok so here we go. 1. Model does not show in model for topic. 2. I have owned the following: orginal NETDUMA, XR500 and now the XR1000. 3. My XR500 IPV6 worked fine. 4. IPV6 will not work rega...
jeremyg237
Feb 10, 2021Luminary
Im also using a CM1000 Netgear modem. Not sure if that what you meant earlier.
jeremyg237
Decided to try some troubleshooting.
1. Firmware was lastest version 38. I also tried 36. Both did not work.
2. Rebooted modem, update PC to include windows. On 38 and 36 Did not work.
3. Tried setup wizard on 38 and 36. It also detected DHCP, but still did not work.
Tried Auto config, dhcp and auto detect in firmware 38 and 36. Did not work.
When I look on the IPVS page it is showing DHCP addresses under WAN and LAN. But still does not work.
- Netduma-LiamFeb 10, 2021NetDuma Partner
Fraser was talking about your physical setup: Modem (CM1000) -> XR1000 -> Connected Devices.
The latest version for the XR1000 is 1.0.0.52, I'd suggest upgrading to this and performing a factory reset after the upgrade.
https://www.netgear.com/support/product/xr1000#Firmware%20Version%201.0.0.52
- jeremyg237Feb 10, 2021Luminary
https://www.downloads.netgear.com/files/GDC/XR1000/XR1000-V1.0.0.52_1.0.38.zip
This is why I put 38.
- Netduma-FraserFeb 10, 2021NetDuma PartnerThanks for the information so far. Can you take a look at the Device Manager please and see if the Xbox gets a local IPv6 address there?
- NikciDApr 15, 2021TutorThat's not going to work. I have the latest and it still doesn't work.
- NikciDApr 15, 2021TutorMine detected dhcp and a couple of times (oddly enough) it detected 6 4 tunneling. I think it's broken.
- NikciDJun 16, 2021TutorYes, it's definitely broken. I had the same experience. I'm a developer and I can assure you that this model is broken and they have to deliver a fix. It's really disappointing. I returned mine and reverted back to my xr500. This is a serious defect. You would think that this world be resolved by now. I am now OkYou've at other gaming routers to weigh my options.
- jeremyg237Jul 29, 2021Luminary
And I'm back. Decided to buy another one today thinking it would be good. Guess what. Still no IPv6. Seriously. I dont want to take it back because, well I do not want to. I want it to work. But it dont. :smileyfrustrated:
