jeremyg237
Feb 09, 2021Luminary
IPV6 not working on XR1000
Ok so here we go. 1. Model does not show in model for topic. 2. I have owned the following: orginal NETDUMA, XR500 and now the XR1000. 3. My XR500 IPV6 worked fine. 4. IPV6 will not work rega...
Netduma-Fraser
Jul 30, 2021NetDuma Partner
Make a custom port forwarding rule for a device you want to test with then port forward that port
jeremyg237
Jul 30, 2021Luminary
Done. Now we just need to wait I guess. Put the potforward rule on my XBOX series x.
- jeremyg237Jul 31, 2021Luminary
Turned on th xbox this morning and it was in ipv4 mode and moderate. Asaid an issue with UPNP. Found some articles on the community page concerning ICMP ipv6. Looks like this is a biger issue in the community.
- NikciDJul 31, 2021TutorJeremy, yes it is. It's the same error that I've gotten and probably anyone with this model that desires to use ipv6. Netgear knows that they released a porridge with a huge defect. The worst part is that they have not released a fix. This router has been out too long to have this kind of bug. This is a performance defect. I'm ashamed of the developers that work for Netgear and Netduma. This is unacceptable.
Also while going through something on my PC I noticed I was on a public network for firewall setting. Changed it to private. I did the following beloow.
- Search for Windows Firewall, and click to open it.
- Click Advanced Settings on the left.
- From the left pane of the resulting window, click Inbound Rules.
- In the right pane, find the rules titled File and Printer Sharing (Echo Request - ICMPv4-In).
- Right-click each rule and choose Enable Rule.
I enabled all the ipv6s .
Turned my xbox back on and it had ipv6 on it with open nat. Hoping that the PC could not communicate with the router with the firewall not allowing ipv6. We shall see.
- Netduma-FraserJul 31, 2021NetDuma PartnerKeep us posted jeremy!
- jeremyg237Aug 01, 2021Luminary
All,
It did not work. XBOX is back to IPv4 plus moderate and UPNP problem. Once I went offline and back on it changed to IPv4 nat open. Very disapponting at this stage. What ever you did to the XR500 you need to do it to the XR1000. Something is seriously wrong with the modem and IPV6.
- Netduma-FraserAug 01, 2021NetDuma PartnerThe team will take a look, thanks for your feedback!
- jeremyg237Aug 02, 2021Luminary
This has been going on for a very long time. Do you think there is going to be a quick fix soon or this is going to take time to fix since it has not been fixed yet. I don't want to be stuck with a router that does not do what I need and want for the price. I believe best buy gives me 30 days to return. This will be the second time I purchased this router. If I return it again it will be the last.
- Netduma-LiamAug 03, 2021NetDuma Partner
Unfortunately we don't know as this is an issue that Netgear will need to resolve, I'd love to be able to give an ETA but there simply isn't an estimate I can give at this time.
- SichSep 24, 2021Initiate
Hi,
Same problem here with IPV6.
The router get the good ipv6 prefix.
Those public IPV6 are distributed on the network, with the good gateway (the router public ipv6). I can ping the router ipv6, but I can't go outside, like there is no routing or some firewall on router side that prevent ipv6 packet to go outside...
The problem is not on computer side, as I can contact the router directly with ipv6 without problem.
Finally anyone was able to configure properly ipv6 with the XR1000 ?
- Netduma-LiamSep 24, 2021NetDuma Partner
What firmware version are you running? Netgear released a firmware recently but I don't believe IPV6 is mentioned in the Release notes. I'd certainly still suggest upgrading to it if you haven't already as it's worth a try!
- NikciDSep 24, 2021TutorIt's probably not going to work. There's no patch notes concerning IPV6. As a customer and progressively, I have to wonder why Netgear has not addressed such an important feature. This should be a priority fix. However, they are not addressing this "defect". I think you'd have a better chance returning the XR1000. It's unfortunate but true. I went back to my XR 500 because I couldn't locate an XR 700.
It's the last version : XR1000 1.0.0.58_1.0.44
I can propagate the subnet from my ISP on my local device but impossible de reach anything outside my network in ipv6... ipv4 work without problem.
And there are no advanced usage to make more test, check if there are some firewall rules somewhere that could cause issue....
It's in time like that, that I'm happy when I can work with real linux device and just use command line to check everything.... But I wanted some "easy setup".... I should just take a good access point and build my own router...
[EDIT]
I have try to reboot the router, but now it just doesn't get the ipv6 configuration from the ISP (was fine before the reboot)...
Will just wait for the next firmware upgrade....
[/EDIT]
- Whiskey8Mar 10, 2022Guide
Just bought a XR1000 yesterday. Same issue, DumaOS is showing IPv6 but Xbox Series X only getting IPv4 via LAN using DHCP.
- NikciDMar 10, 2022Tutor
I don't think that Netgear cares about the fact that they have delivered a non- functioning product (pretty much). Many games don't function properly without using ipv6. This router has been out for quite some time and they have yet to fix it. That says to me that they are not interested in quality or fixing this very important bug.
- Netduma-LiamMar 10, 2022NetDuma Partner
Whiskey8 What firmware is the XR1000 running, did it auto-update to the latest?
If you connect you xbox directly to the modem/router above the XR1000, does it then get IPv6?
Thank you for the response. The app checked during setup and I checked again through Duma, both said it was current with 1.0.0.58
Looks like it's good now, might have just taken a bit to propogate. Xbox is now showing both IPv4 and IPv6.
I was getting IPv6 direct from modem and with the router this one replaced, TP-Link Archer 5400. Still not getting the speeds I pay my ISP for but this new Nighthawk is giving me about 20% faster download speeds than the archer was. Upload is weirdly a lot lower via LAN but it's still above what I need.
