jeremyg237
Feb 09, 2021Luminary
IPV6 not working on XR1000
Ok so here we go. 1. Model does not show in model for topic. 2. I have owned the following: orginal NETDUMA, XR500 and now the XR1000. 3. My XR500 IPV6 worked fine. 4. IPV6 will not work rega...
Netduma-Liam
Mar 10, 2022NetDuma Partner
Whiskey8 What firmware is the XR1000 running, did it auto-update to the latest?
If you connect you xbox directly to the modem/router above the XR1000, does it then get IPv6?
Whiskey8
Mar 10, 2022Guide
Thank you for the response. The app checked during setup and I checked again through Duma, both said it was current with 1.0.0.58
Looks like it's good now, might have just taken a bit to propogate. Xbox is now showing both IPv4 and IPv6.
I was getting IPv6 direct from modem and with the router this one replaced, TP-Link Archer 5400. Still not getting the speeds I pay my ISP for but this new Nighthawk is giving me about 20% faster download speeds than the archer was. Upload is weirdly a lot lower via LAN but it's still above what I need.
