heidarren
Jun 19, 2018Tutor
IPv6 unusable
My ISP IPv6 is using PPPoE, same with IPv4, and VLAN 500.
The IPv6 just never work in any Netgear products that I own, including R7800, R8500 and XR500.
It works in any other brands that I have, ...
Netduma-Fraser
Jun 19, 2018NetDuma Partner
What issues are you having with IPv6? Only thing I'm aware of is Anti-Bufferbloat doesn't work correctly which will be implemented.
Normally recommend disabling IPv6 as doesn't provide any benefits over IPv4.
- KillhippieJun 20, 2018Prodigy
Netgear filter ICMP IPV6 Fraser when it shouldnt be. Just google Netgear IPV6 Filter ICMP and you will see its been going on for years and they refuse to do anything about it.
