immuda
Mar 30, 2023Tutor
Ipv6 What option should i choose?
NightHawk XR1000 Gaming router XR1000 1.0.0.64_1.0.49 I am on Etisalat (my internet provider), i need to enable IPV6 so that i need to know which option should i choose so that Ipv6 is enabled. ...
- Mar 30, 2023
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Mar 30, 2023Guru - Experienced User
I would ask the ISP, the ISP should have this information.
- immudaMar 30, 2023TutorMy ISP says ask netgear
- FURRYe38Mar 30, 2023Guru - Experienced User
I guess try AUTO.
https://kb.netgear.com/24006/How-do-I-set-up-an-IPv6-Internet-connection-on-my-Nighthawk-router
https://kb.netgear.com/24012/How-do-I-set-up-a-fixed-IPv6-Internet-connection-on-my-Nighthawk-router
Be sure the ISP provides native IPv6 support. Again they should have this information. Modes depends on what the ISP puts out. Not what the router can do. It depends on what the ISP configures IPv6 for there services.
- immudaMar 30, 2023TutorIf i use my ISP provide router i get IPv6 on my network, but if use my own router i don’t or unable to.
