immuda
Mar 30, 2023Tutor
Ipv6 What option should i choose?
NightHawk XR1000 Gaming router XR1000 1.0.0.64_1.0.49 I am on Etisalat (my internet provider), i need to enable IPV6 so that i need to know which option should i choose so that Ipv6 is enabled. ...
- Mar 30, 2023
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Netduma-Fraser
Mar 30, 2023NetDuma Partner
Auto or passthrough should work for you, do they work at all?
immuda
Mar 31, 2023Tutor
let me check and get back.
