xbentleyx
Dec 02, 2020Aspirant
Is firmware 2.3.2.66 bugged? (Nighthawk XR450)
Hi All, Hoping to find some assistance here ASAP. We have 4 kids home schooling so connectivity is a must have! The other day the "wifi went out" suddenly on my kids. Then I noticed my work lapt...
Dec 02, 2020Guru - Experienced User
How many devices do you have connected at once?
Try the XR wifi with out the link sys online OR, disable the wifi on the XR router and setup the Linksys Velop in AP mode for wifi.
- xbentleyxDec 02, 2020AspirantIt’s a Fios ont
The WiFi is not the problem as it happens on dozens of wired devices also.
I haven’t done a factory reset unless that’s the only option. I spent 8 hours configuring the Xbox ports do get open NAT on our 3 xboxes not to mention logically naming all my devices etc. There are 40- 50 connected devices online at any give time.- xbentleyxDec 03, 2020AspirantForgot to mention that the XR450 WiFi is off, only the Velop WiFi is on in bridge mode.
- Netduma-FraserDec 03, 2020NetDuma PartnerDo you require anything such as PPPoE, VLAN etc for a connection? Please go to Settings > Monitoring > Connection Status and just double check to see when the lease is obtained/expires. Give your devices reserved IPs in LAN Settings and that should help.
- FURRYe38Dec 03, 2020Guru - Experienced User
Lets do a factory reset.
You don't need to PF xbox rules. All you need to do is enable uPnP and set NAT Filter to OPEN if you have two or more game consoles onlline at the same time.
