xbentleyx
Dec 02, 2020Aspirant
Is firmware 2.3.2.66 bugged? (Nighthawk XR450)
Hi All, Hoping to find some assistance here ASAP. We have 4 kids home schooling so connectivity is a must have! The other day the "wifi went out" suddenly on my kids. Then I noticed my work lapt...
xbentleyx
It’s a Fios ont
The WiFi is not the problem as it happens on dozens of wired devices also.
I haven’t done a factory reset unless that’s the only option. I spent 8 hours configuring the Xbox ports do get open NAT on our 3 xboxes not to mention logically naming all my devices etc. There are 40- 50 connected devices online at any give time.
xbentleyx
Dec 03, 2020Aspirant
Forgot to mention that the XR450 WiFi is off, only the Velop WiFi is on in bridge mode.
- Netduma-FraserDec 03, 2020NetDuma PartnerDo you require anything such as PPPoE, VLAN etc for a connection? Please go to Settings > Monitoring > Connection Status and just double check to see when the lease is obtained/expires. Give your devices reserved IPs in LAN Settings and that should help.
- xbentleyxDec 03, 2020AspirantAre you suggesting static IP addresses for all of my devices?
