JonSnowKnowsNad
Feb 10, 2020Apprentice
is it possible that my xr500 is the problem when streaming to twitch
i called my isp which is Rogers Cable and i told them my connection is unstable when uploading to twitch. and the guy told me to try connecting to my modem instead of the router/xr500 by ethernet of ...
Netduma_Alex
Feb 11, 2020NetDuma Partner
It's possible, but there are other potential causes.
First we should eliminate the possibility that QoS is the problem. To do this, go to QoS > Anti-Bufferbloat, open the side menu and tick Disable QoS. Now try streaming again and see if you fare any better.
If the problem remains, you can turn QoS back on again. We will try some traffic prioritization.
JonSnowKnowsNad
Feb 15, 2020Apprentice
it is QoS being enabled that is causing this. I turned QoS off and stream is stable and no rubber banding during call of duty
- Netduma_AlexFeb 17, 2020NetDuma Partner
Hm, well that's interesting. It doesn't nessercarily mean that QoS is broken, it could just be misconfigured. Prioritizing the wrong thing. Check my reply to your other post. I think you'll need to specifically prioritize call of duty.
- JonSnowKnowsNadFeb 17, 2020Apprentice
and what about streaming? plus i play on console so i dont know how to traffic prioritize one game on console.
- Netduma_AlexFeb 18, 2020NetDuma Partner
If you're using a console you can just add it to Traffic Prioritization using the Games Console profile. This will cover all UDP traffic so hopefully will cover gameplay and not streaming.
