gycuk1
Apr 01, 2021Apprentice
Is Mesh working Nighthawk yet
Hi I looked through the fourm and found that the XR series doesnt support MESH. The posts were sometime ago and things have changed, so does anyone know if there has been and update and this func...
- Apr 01, 2021
It should work off the 5ghz of your xr700.
I haven't personally used it but I've seen several people on here who've used the XR line and mesh extenders.
Apr 01, 2021Guru - Experienced User
The triband mesh extenders work great.
I've got an EX8000 and have used it with many routers and haven't had issues.
gycuk1
plemans wrote:The triband mesh extenders work great.
Thats Great, to hear and its not in AP mode or anything like that and you get full signal or best you can where ever you wander?
The XR700 reaches everywhere in the home as its upstairs. As it looks like we are staying home this year due to covid we will spend alot of time in the garden. The XR700 signal tails off in the gardenand was looking to improve it.
In the Garden room we have an old asus router acting as a bridge for all the ethernet stuff i was going to replace that with an EX8000.I could set the old router up as an AP but everytime the kids move around we would have to keep changing over the Network. Looking around there were posts saying the XR Routers dont work with Mesh?
Regards
Jon
- plemansApr 01, 2021Guru - Experienced User
The XR devices do work with mesh extenders. the only issue is that when the ex8000 is hardwired in and running in access point mode, the mesh doesn't function. it does function if ran in extender mode (acting as a repeater)
I can't tell you if it'll reach in your case because everyones home/setup is different. My home is 3200 sqft and I can run off an RAX200 and the EX8000. I have coverage over my whole home and much of my yard.
- gycuk1Apr 01, 2021Apprentice
plemans wrote:The XR devices do work with mesh extenders. the only issue is that when the ex8000 is hardwired in and running in access point mode, the mesh doesn't function. it does function if ran in extender mode (acting as a repeater)
I shall not hard wire in i can live with that. the 5gz signal is fine in the Garden room i shall give it a go. Many many thanks i almost didnt buy one as the posts i was reading said they dont work with the XR range. i take it as its running MESH devices switch automatically between the RAX200 and EX8000? and would do with my XR700
