Str1d3r
Aug 03, 2022Aspirant
Is readyshare a thing of the past
I recently picked up an XR1000 router and a CM700 modem to replace an older WNDR4500 router that worked fine and ditch the cable company's monthly bill on the modem. I never utilized the readyshare o...
Str1d3r
Aug 04, 2022Aspirant
Yes I have.
Netduma-Liam
Aug 05, 2022NetDuma Partner
If you simply connect the drive, then open up Windows Explorer and enter \\readyshare into the search bar, does that bring up the drive?
- Str1d3rAug 05, 2022Aspirant
Yes. Only from my desktop.
Edit, Sorry for the delay. I am an on call refrigeration tech and have not had much time during this heat wave
- Netduma-FraserAug 06, 2022NetDuma PartnerDoes it work if you use the HTTP option and use the link on each device?
