WacoJohn
Jan 06, 2021Luminary
Is the problem in XR500 settings?
I don't know that the problem lies within the router. Here is the story: POLK MAGNIFI MINI sound bar on a Vizio Smart TV. All are WiFi connected (including Tivo Bolt). The Polk has a white LED ...
- Jan 06, 2021You can find the IGMP option in WAN Settings so you could try that. Are you using Smart Connect for WiFi? If so disable that and connect the device to 2.4GHz manually, does it work then?
Netduma-Fraser
Jan 06, 2021NetDuma Partner
