harrisonethan
Jan 24, 2023Tutor
Is there a Netgear router for gaming PCs?
Hello Folks, I'm asking a question in this community because I've been facing some issues with the speed of the internet while playing games on my PC. I'm not that much of a gamer, but I do enjo...
- Jan 24, 2023
harrisonethan wrote:
I'm looking for a router that is fast and affordable....
The affordable but may be a push. Netgear makes routers aimed for just that market. But at a price.
Best Gaming Routers - ?Nighthawk Pro Gaming - NPG: Power to Win
harrisonethan
Jan 24, 2023Tutor
Thanks for getting connected.
Yah, I've heard about this one, the Nighthawk Pro, but it is a bit expensive. However, I'm not sure how well it will work with my old PC.
These two are great. The Nighthawk Pro XR500 and XR1000 would be fine for a high performance monitor.
- 4 LAN and 1 WAN Gigabit Ethernet ports
- Powerful WiFi 6 Technology
- Triple-Core 1.5GHz Processor
- Latest DumaOS 3.0 Software
- Up to 5.4Gbps WiFi speeds
I've got this one as well; it's affordable, but I don't know whether or not it is good for gaming: - https://www.netgear.com/uk/home/wifi/routers/rax50/
I've got some monitor options as well: https://www.lenovo.com/gb/en/d/accessories-and-monitors/gaming-monitors/
Thanks for your suggestion.
Jan 24, 2023Guru - Experienced User
I found my XR1000 on Amazon used for cheap. Solid working router during my testing of it. Worked well when I have it online.
- harrisonethanJan 25, 2023Tutor
FURRYe38 Thanks for your information!
- FURRYe38Jan 25, 2023Guru - Experienced User
đ
