MrDsg44
Dec 10, 2019Aspirant
Is there an option for "Access Control" on XR300?
Hello. I had a Netgear Nighthawk (something) router before just buying this Nighthawk XR300 Router. Sadly I did not check properly and it seems that this XR300 does not have "Access Control" like...
- Dec 10, 2019Unfortunately that feature is not available on the router at present. The only way to block devices at the moment is using the Device Manager but you will have to do this manually for each device.
Netduma-Fraser
Dec 10, 2019NetDuma Partner
