Angrybee
Aug 22, 2018Tutor
is there away to get my rounter to run another speed test?
i just upgraded my net to Gigabit so how do i get my router to be like hey your net is faster then before?
Netduma-Fraser
Aug 22, 2018NetDuma Partner
You can do the setup wizard or just do speedtest.net and input the speeds into Anti-Bufferbloat options
Angrybee
Aug 23, 2018Tutor
Okay my router seems to be stuck at this screen
- FURRYe38Aug 23, 2018Guru - Experienced User
Power OFF the router then back on. While you do this, clear the browser cache, close the browser then reopen.
Try a different browser, FF or Opera.
- AngrybeeAug 23, 2018Tutor
okay i have did this and my router did what it should of been doing but how ever i got that same page again it blinked and then it show everything was all good then it gave me that same screen again to where it went back to the screen and it got stuck again. and my rounter doesn't seems to be picking up my new speeds at all. do i need to shange the ethernet cables out?
- FURRYe38Aug 24, 2018Guru - Experienced User
I found that if I cleared the browser cache, exited the browser then relaunch the browser, I was able to get past this message.
