Retired_Member
Oct 25, 2022Is there going to be a new update for XR 450
is there going to be a new update for XR 450
Retired_Member
Oct 25, 2022What kind of bugs are there?
Netduma-Fraser
Oct 25, 2022NetDuma Partner
Device manager appearing offline, CC Upload not working when using PPPoE as well as the issues caused by a factory reset not executing properly to name a few.
- Retired_MemberOct 25, 2022Who uses PPPOE? It's basically a protocol for manual internet ISP providers or whatever
Are you guys also going to add new applications to for updates? Because I'm also waiting for newer updates to come out that allow different applications on the website
- Netduma-FraserOct 25, 2022NetDuma Partner
It depends on your internet provider, some require it otherwise they can't get internet and so for those using it QoS isn't as effective, it's been an issue for a little while now so we're keen to get it sorted.
Could you clarify what you mean exactly for applications?- Retired_MemberOct 25, 2022
Like are you guys going to add new features later on?
