PapaLung
Aug 11, 2022Apprentice
ISP provided Modem with XR1000?
Should I be running my isp's Modem with the XR1000? If so, would I need to run isp Modem in bridge mode or just disable the wifi capabilities so I could utilize the xr for wifi and ethernet? I have a replacement xr1000 on the way and I want to avoid as many obstacles as humanly possible. I'm currently running a nighthawk cm2050v Modem, xfinity high speed internet down and 42 up. The modem xfinity provides would be an XB8 router Modem combo w phone line capabilities. Any advice is greatly appreciated.
- You need A modem but it doesn't have to be your ISP modem, you could do so if you wish and put it in bridge or like you said leave it in router mode and disable its WiFi. If you were to do that then you would need to enter the XR WAN IP into the modem DMZ to ensure you can get an Open NAT.
The CM2050 is a modem only and would be a good recommended modem to use the XR1000 router with. The CM modem doesn't have built in router or wifi.
The ISP modem would have built in wifi and a router already, it would be recommended to bridge that modem if you used it with the XR router.
- Netduma-FraserNetDuma PartnerYou need A modem but it doesn't have to be your ISP modem, you could do so if you wish and put it in bridge or like you said leave it in router mode and disable its WiFi. If you were to do that then you would need to enter the XR WAN IP into the modem DMZ to ensure you can get an Open NAT.
