TonVanOostveen
Jan 21, 2021Aspirant
Issue and Fix: Netgear XR500: VPN package drops
To help anyone with VPN issues with the XR500. I noticed connection drops in my companies chat client and other connection instability using VPN connection. My XR500 which I have set up as wifi rou...
- Jan 21, 2021
This might be more useful in the appropriate bit of this community.
michaelkenward
Jan 21, 2021Guru - Experienced User
- TonVanOostveenJan 21, 2021AspirantOk. Fine with me.
I can't find an option to move this, can you move this to the right place?
Ton- Netduma-FraserJan 21, 2021NetDuma PartnerThank you for the report, this is something we are aware of and will be fixing.
- TonVanOostveenJan 22, 2021Aspirant
Just to be sure ;)
It is a (software) VPN client program on my laptop to connect to my companies network where package/connection drops happened with/in the VPN session.
It is _not_ about configuring a VPN on the XR500 for all my internet traffic (I don use that).Regards,
Ton
