TonVanOostveen
Jan 21, 2021Aspirant
Issue and Fix: Netgear XR500: VPN package drops
To help anyone with VPN issues with the XR500. I noticed connection drops in my companies chat client and other connection instability using VPN connection. My XR500 which I have set up as wifi rou...
- Jan 21, 2021
This might be more useful in the appropriate bit of this community.
TonVanOostveen
Ok. Fine with me.
I can't find an option to move this, can you move this to the right place?
Ton
Ton
Netduma-Fraser
Jan 21, 2021NetDuma Partner
Thank you for the report, this is something we are aware of and will be fixing.
- TonVanOostveenJan 22, 2021Aspirant
Just to be sure ;)
It is a (software) VPN client program on my laptop to connect to my companies network where package/connection drops happened with/in the VPN session.
It is _not_ about configuring a VPN on the XR500 for all my internet traffic (I don use that).Regards,
Ton
- Netduma-FraserJan 22, 2021NetDuma PartnerThanks for clarifying, that's what we understand the issue to be with so glad we're on the same page. I'm hopeful we'll get that sorted in one of the beta builds.
