Compoza_
Mar 13, 2021Luminary
issue entering the DNS
Hi! The router doesn't save the new DNS numbers I entered. When I check my DNS on my computer or on PS4, it just shows the ISP's DNS, not the one I would like to use. It's google DNS: 8.8.8.8, 8....
- Mar 13, 2021It will use the DNS you have set on the router don't worry :)
Netduma-Fraser
Mar 13, 2021NetDuma Partner
You enter the DNS on the router itself, devices themselves will show the router IP as the DNS as they connect to that first and then will use the DNS you set.
Compoza_
Could you explain it in easy english, sorry, my english is not the best :smileylol: :manembarrassed:
- Netduma-FraserMar 13, 2021NetDuma PartnerIt will use the DNS you have set on the router don't worry :)
