Compoza_'s avatar
Compoza_
Luminary
Mar 13, 2021
issue entering the DNS
Hi! The router doesn't save the new DNS numbers I entered. When I check my DNS on my computer or on PS4, it just shows the ISP's DNS, not the one I would like to use.   It's google DNS: 8.8.8.8, 8....
  • Netduma-Fraser's avatar
    Netduma-Fraser
    Mar 13, 2021
    It will use the DNS you have set on the router don't worry :)
