ezambran
Jan 23, 2019Aspirant
Issue in option " Turn off wireless signal by schedule" in new firware V2.3.2.40 Router XR500
Hello, I have a XR500 DumaOS router originally with firmware v 2.3.2.32. The issue is that I cannot make changes in the wireless programming because the options become dimmed after upgrading firmware...
Netduma-Fraser
Jan 23, 2019NetDuma Partner
Is it just Transmission Power Control that is dimmed or is it other settings as well? Do you have smart connect enabled?
- ezambranJan 23, 2019Aspirant
It's just the Transmit Power Control. Yes, I have enable the Smart Connect option.
- Netduma-FraserJan 24, 2019NetDuma PartnerIf you disable smart connect are you able to edit the option?
- ezambranJan 24, 2019Aspirant
I've disabled smart connect but the option still can't be edited. I've attached an image.
