ezambran
Jan 23, 2019Aspirant
Issue in option " Turn off wireless signal by schedule" in new firware V2.3.2.40 Router XR500
Hello, I have a XR500 DumaOS router originally with firmware v 2.3.2.32. The issue is that I cannot make changes in the wireless programming because the options become dimmed after upgrading firmware...
Netduma-Fraser
Jan 23, 2019NetDuma Partner
Is it just Transmission Power Control that is dimmed or is it other settings as well? Do you have smart connect enabled?
ezambran
It's just the Transmit Power Control. Yes, I have enable the Smart Connect option.
- Netduma-FraserJan 24, 2019NetDuma PartnerIf you disable smart connect are you able to edit the option?
- ezambranJan 24, 2019Aspirant
I've disabled smart connect but the option still can't be edited. I've attached an image.
- Netduma-FraserJan 24, 2019NetDuma PartnerTransmit power control looks editable to me, what happens when you click the 100% beside it?
