ezambran
Jan 23, 2019Aspirant
Issue in option " Turn off wireless signal by schedule" in new firware V2.3.2.40 Router XR500
Hello, I have a XR500 DumaOS router originally with firmware v 2.3.2.32. The issue is that I cannot make changes in the wireless programming because the options become dimmed after upgrading firmware...
ezambran
It's just the Transmit Power Control. Yes, I have enable the Smart Connect option.
Netduma-Fraser
Jan 24, 2019NetDuma Partner
If you disable smart connect are you able to edit the option?
- ezambranJan 24, 2019Aspirant
I've disabled smart connect but the option still can't be edited. I've attached an image.
- Netduma-FraserJan 24, 2019NetDuma PartnerTransmit power control looks editable to me, what happens when you click the 100% beside it?
No, it's still the same. I've attached another image.
