Steinmeg
Mar 30, 2022Star
Issue with content filtering
Have the XR1000, trying to block you tube but not having any luck. Can access it from all devices. I added the rule, tried to hit site after I applied it and it was still active, then also tried after...
- Apr 01, 2022
OK, that might work as a good work around until NETGEAR can release a fix for their Content Filtering feature. Perhaps if you let us know your use case we can help you fine tune it a little further? For example, if you're trying to stop a particular device accessing YouTube after a particular time in the evening you could implement that to.
Netduma-Liam
Mar 31, 2022NetDuma Partner
As far as I'm aware there's a known issue with Content Filtering not working, though it's a features of NETGEAR's settings and here at Netduma we don't have control over their settings.
Could you try adding a new rule to traffic controller for the device you want to block, then select 'Media' from the categories menu and see if that works better?
- SteinmegMar 31, 2022StarI am able to block all media with that option. It is the content filter that seems to not be working like it should. I flip the media rule a d nothing works for streaming wise.
- Netduma-LiamApr 01, 2022NetDuma Partner
- SteinmegApr 04, 2022StarGoing to accept this a a answer, it is a work around. We are 100% streaming so stopping media would stink. I will wait for a patch to block the specific websites, thank you for the information.
