goonplatoon717
Mar 23, 2021Follower
issues accessing dumaos dash board
I already downloaded the night hawk app on my phone, but now I am trying to access my dashboard on the computer so I can customize my geofilter setting. Can someone please assist me?
Jughead76
Aug 23, 2021Aspirant
Sorry it's a netcomm
Netduma-Liam
Aug 24, 2021NetDuma Partner
OK, I'd suggest first finding the WAN IP of the XR by going to the DumaOS interface then System Information. In here you should be able to see it's WAN IP (you'll need to do this after disabling AP mode).
Then, note down this WAN IP and replace the last octet with 1. So if it's WAN IP is 192.168.0.139, note down 192.168.0.1 and put this in your web browser.
Here you should see the ISP modem/routers interface, find the DMZ settings and put the XR WAN IP in here. If possible, find the LAN settings too and make sure the XRs address is reserved/static so it doesn't change in future.
- Jughead76Sep 01, 2021AspirantThank you that worked I have one more question I have netgear wifi 6 mesh extenders mr60 they aren't compatible with the xr1000 is there a work around it I only got them to put more internet coverage at the back of the house
- Netduma-LiamSep 01, 2021NetDuma Partner
In what way are they incompatible? I'm sure we could likely figure it out.
Could you please connect and ethernet cable from one of the LAN ports on the XR to the WAN port on the MR60 main/base node.
Then setup the antennas/access points for the MR60 and see if you can get connectivity.
Once we've confirmed connectivity we can optimise it a little further.
