Jeff321
Mar 22, 2018Aspirant
Issues with Hearthstone disconnections on iPad Air 2
Hi, This has happened multiple times now since I got this router. I never had a problem with my old router. When playing Hearthstone on my iPad Air 2 connected to the WiFi, randomly every sever...
Netduma-Fraser
Mar 22, 2018NetDuma Partner
Hi Jeff, I think 5Ghz may be the problem. It is more unreliable than 2.4Ghz. If you have to game via WiFi I would always recommend 2.4Ghz. So enable that and use that to play and see if you get the same issue.
