Thorfinn
Jun 01, 2020Star
Issues with VOD on TV Devices
Not sure how to explain it properly because english is not my main language I installed the XR500 a month ago using my old modem/router as a bridge and everything works great - i got a PC connected...
Netduma-Fraser
Jun 02, 2020NetDuma Partner
Firstly your English is great, thanks for being clear and concise. Please go to Settings > Setup > WAN Settings. Make sure that Disable SIP ALG is ticked and that Disable IGMP Proxying is UNticked. Then apply and reboot the router, does it work properly after that?
- ThorfinnJun 02, 2020Star
Hey,
Tried that but still no luck :\
- Netduma-FraserJun 02, 2020NetDuma PartnerCan't see the picture as it hasn't been moderated. Disable QoS in the Anti-Bufferbloat menu and see if that makes it work.
well the picture just showing the settings you wanted me to use
I tried disabling QOS and it does'nt help at all.
