Thorfinn
Jun 01, 2020Star
Issues with VOD on TV Devices
Not sure how to explain it properly because english is not my main language I installed the XR500 a month ago using my old modem/router as a bridge and everything works great - i got a PC connected...
Thorfinn
Jun 02, 2020Star
Hey,
Tried that but still no luck :\
Netduma-Fraser
Jun 02, 2020NetDuma Partner
Can't see the picture as it hasn't been moderated. Disable QoS in the Anti-Bufferbloat menu and see if that makes it work.
- ThorfinnJun 02, 2020Star
well the picture just showing the settings you wanted me to use
I tried disabling QOS and it does'nt help at all.
- Netduma-FraserJun 02, 2020NetDuma PartnerIt might be that it's required to be plugged into the ISP hub. Our new software will be available for beta soon which could fix the issue possibly, sign up here and if you get in please do give us feedback on whether it works on not and we can look into it in more detail: http://www.netgearinnovation.com/dumaos-beta/index.html
Hey
not really sure what does it mean being plugged directly into the ISP hub
Anyway i registered for the BETA and I really hope it will help solve the issue because right now I'm paying for that VOD service and it's not usable.
If have any other suggestion regarding settings that might help - please let me know
besides that,
Thanks for time and help : )
