gnemelf
Jul 02, 2019Star
Issues with XR450 and Destiny 2
I have the Nighthawk XR 450 firmware V2.3.2.40 and yes I have done the reset with all ethernet cords disconected. I am having serious issues with destiny 2 for PC, I can play for about 15 minutes ti...
Jul 02, 2019Guru - Experienced User
Have you set a IP address reservation for your PC ON the router?
Is QoS enabled or disabled?
Is others using internet bandwidth when you gaming?
gnemelf wrote:I has now started happening even when I am not gaming that lease renew thing happens and I lose internet til I unplug my ethernet and plug it back in. I feel like whatever is happening is getting way worse and quick.
gnemelf
Jul 02, 2019Star
Not sure on the ip address reservation, qos is enabled with all ports manually added for destiny 2 as priotized, no I am the only device that takes any bandwidth while gaming
- gnemelfJul 02, 2019Star
Another thing that has me really thrown off is I had the router hooked up for about a month without any issues til last weekend when this started to happen. I had nothing setup or turned on as far a features go at that point and I didn't try configuring things until all of this started.
- Netduma_AlexJul 03, 2019NetDuma Partner
I don't know why the leases are renewing as often as they are... But one solution would be to set a reserved IP for your PC, here's how:
Open your router's interface (routerlogin.net), go to Settings > Setup > LAN Setup.
Scroll to the bottom and press Add under Address Reservation, select your device in the reservation table (hopefully it's named, if not, open cmd and use ipconfig) and then press Add.
Now the IP address won't change and hopefully the lease won't constantly renew.
- gnemelfJul 03, 2019Star
I've done the reserved Ip played for about a hour no issues will report back in a couple of days and update.
