gnemelf
Jul 03, 2019Star
Issues with XR450 and Destiny 2
I have the Nighthawk XR 450 firmware V2.3.2.40 and yes I have done the reset with all ethernet cords disconected. I am having serious issues with destiny 2 for PC, I can play for about 15 minutes ti...
Netduma_Alex
Jul 03, 2019NetDuma Partner
I don't know why the leases are renewing as often as they are... But one solution would be to set a reserved IP for your PC, here's how:
Open your router's interface (routerlogin.net), go to Settings > Setup > LAN Setup.
Scroll to the bottom and press Add under Address Reservation, select your device in the reservation table (hopefully it's named, if not, open cmd and use ipconfig) and then press Add.
Now the IP address won't change and hopefully the lease won't constantly renew.
gnemelf
Jul 03, 2019Star
I've done the reserved Ip played for about a hour no issues will report back in a couple of days and update.
- gnemelfJul 05, 2019Star
Had no issues at all yesterday but woke up to this issue
It seems to be happening again even with the reserved ip
[DumaOS] DHCP new event., Friday, July 05, 2019 03:08:13
[DHCP IP: 192.168.1.2] to MAC address 60:45:cb:a0:d2:da, Friday, July 05, 2019 03:08:13
[DumaOS] DHCP lease change., Friday, July 05, 2019 03:08:10
[DumaOS] DHCP new event., Friday, July 05, 2019 03:08:10[DHCP IP: 192.168.1.2] to MAC address 60:45:cb:a0:d2:da, Friday, July 05, 2019 03:08:10
[DumaOS] Error parsing line in ARP table: 'fe80::217:10ff:fe84:eddd dev brwan lladdr 00:17:10:84:ed:dd router STALE', Friday, July 05, 2019 03:08:08
[DumaOS] Error parsing line in ARP table: 'fe80::217:10ff:fe84:eddd dev brwan lladdr 00:17:10:84:ed:dd router STALE', Friday, July 05, 2019 03:07:51
[DumaOS] DHCP lease change., Friday, July 05, 2019 03:07:43
[DumaOS] DHCP new event., Friday, July 05, 2019 03:07:43[DHCP IP: 192.168.1.2] to MAC address 60:45:cb:a0:d2:da, Friday, July 05, 2019 03:07:43
[DumaOS] DHCP lease change., Friday, July 05, 2019 03:07:19
[DumaOS] DHCP new event., Friday, July 05, 2019 03:07:19[DHCP IP: 192.168.1.2] to MAC address 60:45:cb:a0:d2:da, Friday, July 05, 2019 03:07:19
[DumaOS] Error parsing line in ARP table: 'fe80::217:10ff:fe84:eddd dev brwan lladdr 00:17:10:84:ed:dd router STALE', Friday, July 05, 2019 03:07:19
[DumaOS] Error parsing line in ARP table: 'fe80::217:10ff:fe84:eddd dev brwan lladdr 00:17:10:84:ed:dd router STALE', Friday, July 05, 2019 03:07:16
[DumaOS] DHCP lease change., Friday, July 05, 2019 03:06:38- Netduma_AlexJul 05, 2019NetDuma Partner
Could you try logging into your router and going to Settings > Advanced Settings > IPv6 and setting Internet Connection Type to Disabled.
I went to do that that but it seemed that was what it was already set at. I set it to that and clicked apply again just in case. still havthing the same issue though
log is filled with the
[DumaOS] DHCP lease change., Friday, July 05, 2019 10:29:54
[DumaOS] DHCP new event., Friday, July 05, 2019 10:29:54
[DHCP IP: 192.168.1.5] to MAC address e4:3e:d7:9d:8e:44, Friday, July 05, 2019 10:29:54
and this one seem to be paired always get them when it happens.
[DumaOS] Error parsing line in ARP table: 'fe80::217:10ff:fe84:eddd dev brwan lladdr 00:17:10:84:ed:dd router STALE', Friday, July 05, 2019 10:29:57
Is it possible that its just a bad router or something is corrupt in the firmware? seeing as the problem doesn't exist when that router isn't hooked up.
