Cornerback21
Jan 06, 2020Aspirant
Issues with XR500 Geo-Filter Apex Legends
Im from central Wisconsin, trying to get into lobbies from the iowa server since those have the lowest ping times 20-25. All of the servers show up for a few seconds at the Apex Legends loading scree...
Netduma-Fraser
Jan 07, 2020NetDuma Partner
Have you selected the server on Apex that you want and then mirrored that setting on the Geo-Filter? If you allow the one from Texas does another server show up when you're in the game or is it just that Texas server? Use Spectating Mode and just play normally, do you see any other servers on the map that you get connected to or is it always the Texas server despite the server you've selected in the game? What is the ping to the Texas server?
Cornerback21
Jan 07, 2020Aspirant
I’ve tried choosing 3 Iowa servers on the game and closing the range on the filter too only hit Iowa and so forth, but then Iowa servers disappears and only ones pop up in Texas, shows them get blocked a few times, then it shows a peer server. At this time I try matching making and get kicked for connection to server issue.
