VegasClips
Aug 10, 2021Aspirant
Just purchased the XR 500 and I need help with high ping on Apex Legends - 2021
Hey all, Just purchased the XR 500 and I need help with high ping on Apex Legends. I have watched most of the "xr 500 setup, settings, apex legends" videos on youtube but nothing really helps lower ...
VegasClips
Aug 13, 2021Aspirant
Hi Fraser, here is what I sent LIAM:
So I went ahead and returned the refusbished XR500 router and bought the same router but this time brand new. If I drag my location to the ocean as you suggested, and do 1500km, I do get lower pings at times but the major drawback is I can't find a game. Check out my screen shots. 1. This where the server is trying to load me in, look how far that is? https://ibb.co/mRc9ZKq 2. This is what ApexLegends game shows almost every time I tried to launch matchmaking: https://ibb.co/PrHd99v
I don't know the ping, that was yesterday and at the start of each game the server is in a different place.
Netduma-Fraser
Aug 13, 2021NetDuma Partner
I'd recommend you first upgrade to the beta: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/New-Firmware-v2-3-2-120-XR500/td-p/2071196/ then you can use the Ping Heatmap feature and that will help you find where the servers are located on the map.
Next time that server appears that was blocked outside your radius, ping it, it may be lower than you expect - servers can be mislocated on the map. We likely need to do a cloud update as well to prevent that error and that may be a server you need to allow.
