VegasClips
Aug 10, 2021Aspirant
Just purchased the XR 500 and I need help with high ping on Apex Legends - 2021
Hey all, Just purchased the XR 500 and I need help with high ping on Apex Legends. I have watched most of the "xr 500 setup, settings, apex legends" videos on youtube but nothing really helps lower ...
Netduma-Fraser
Aug 19, 2021NetDuma Partner
Click on the specific connection, the ping panel will then appear on the bottom right of the Geo-Filter page and then you can allow it there
VegasClips
Aug 19, 2021Aspirant
It says something about Auto Ping being on when I click on the icons in the map
- Netduma-FraserAug 19, 2021NetDuma PartnerOkay so click the 3 line icon top left of the Map panel, then disable it and you can then ping manually
